Additional equipment connected to ignition
Does anyone know how to connect something to the ignition switch (i.e. when i start the bike it turns on) on a 2015 sportster (sefenty-two in this case)
I tried the red and orange wire on the 10amp fuse and it turns out it doesn't do it as it is always on. I think this is due to the integrated circuitry. So what is the correct way to do it ?
Thanks
Thanks
Relay will be good I agree but I am really running out of space .. so my initial idea was directly to the fuse ... as it turns out not the solution. I mean come on there should be something that turns on with ignition right :/ what is the wiring diagram of the accessory plug maybe i can use that
