Lol, that is a strange one. I'd unplug the battery for half an hour to see if it clears itself.There is a way to scroll through any fault codes that are stored. See the sticky thread https://www.hdforums.com/forum/sport...des-dtc-s.html
I checked the fault codes via the Fuel pak... nothing came up cant get to dealer till next Saturday. disconnected battery overnight and still same ...checked every molex....has to be in ECM.
other than the intermittent neutral light that I see has been an issue for some on the forums ...no problems. we will see what dealer says and I will post results.
I don't know squat about the Fuel Pak, pull the codes per the Stickies posted on the forum.
