1200t handlebars
1200t handlebars
Dear friends,
I was thinking of changing out bars on my 1200 T (the stock ones are ****!!!>..!)
The stock ones measure 6” from clamp to inner end of bars.
I’m looking at the licks 9” fat z bars.
Any idea if I can stretch the stock brake lines to fit?
If not, what should I be ordering from magnum? I emailed the guys because I was uncertain about which set to order (I have ABS brake system) and wasn’t sure if I need a full set or just the uppers.
Thanks for all your advice.
I have the 1200 T Handlebars.....search my name on this forum and you'll see posts and pics of it. You won't need to change the stock lines unless you use risers. I have 2 inch risers so i needed to change the front brake line to a 38 inch one, which fit perfectly.
Correction: I do not have the 1200T bars. My apologies for the confusion. They are 1200s bars.
mikesova
07-14-2013 10:12 PM
