HElp! Problem getting proper amount of fuel. I've tried EVERYTHING
Help! Problem getting proper amount of fuel. I've tried EVERYTHING
About 5 days ago my 2002 XLH 1200 broke down on the side of the road. I started it back up and it ran to my house. It will start and rev in neutral with no problem. It also does fine moving through the yard. Once I get on the street and get to the top of first gear it will start stumbling. I can work my way up through the gears, but it will usually run best around 2400-2600rpms. Pulling the choke while losing power usually give me power back, but sometimes it only makes it a little better. Ive made probably 12 test runs (1-mile) and its died several times but will start right back up. Really the only thing that Ive messed with since I bought it is the wiring with the tail light, and internal wiring in my bars (two months ago), and I put drag pipes with no baffles. Changed the pipes a month or two ago and rejetted. Hadnt had any problems so far.
It feels like its running out of fuel so thats mostly what Ive been troubleshooting. I've checked the vacuum petcock, cleaned the jets, and checked the vacuum piston. There was some tank liner loose in my tank so i pulled it off and cleaned the inside of it. The accelerator pump squirts a good strong stream. I had a vacuum leak at my intake manifold so i replaced both gaskets. Ive also checked the float bowl level, my battery connections, and the coils. I have no idea what to do next.
cwsharp
03-13-2009 03:13 PM
