I have a problem related to carburetor
The bike will not start unless I spray starter fluid in it. Then it runs until the starter fluid burns out.
Next step I checked the fuel lines and the fuel lines are good and filter is good. Fuel is flowing perfectly into the carbs. I have no experience with carbs really.
So I Said what if i forced fuel into the carbs somehow like a fuel pump. I took my gas line from my boat which has a primer bumb inline. I pumped the fuel till it leaked out the carbs. I can then start the bike right up and it runs perfect until the fuel runs out of the carbs. Meaning I have to prime the bumb again to get it started or continue priming the bumb to keep it running.
I feel like its not sucking in gas. Which I beileve its suppose to.
Like I said I dont know carbs much but it runs fine when I force fuel into the carbs. But then doesnt continue sucking in gas. My guess was something do to with the float bowl
it was started a week ago. Yes i know its not getting fuel at all thats the problem. IS there a mechanism that sucks in fuel like a fuel pump. My outboard has a fuel pump. I dont see any fuel pump on the carb or near it. Im assuming it just sucks fuel into the bowl with gravity and stops when float goes up or am I wrong.
I will give the bowl a wack and see if maybe that loosens the float.
What type of carb is it? Year and model?
All carbed harleys are gravity fed. I would isolate the feed line, and give is some fuel from a separate source. This will let you know if the issue is in the carb or if the screen/petcot is the issue. If it is the carb, most S&S and Mikuni Carbs have millions of videos on you tube and an infinite number of gasket, jet, and float rebuilt kits.
So the feed line is not an issue. I also changed all the fuel lines to make sure they were not bad.
sportster 1200 1996 I believe
I use almost 100% ethanol in my car for years. Runs alot better and cleaner
and I use 10% ethonol in my boat for years. I think 10% is pretty much the norm nowdays
Is there fuel being supplied to the carburetor?
