change from cable to fly by wire throttle?
You are talking major modifications if you want to do that. You will need, throttles, throttle body, new wiring harness, new ecm, bcm, handle bars, and other related computers, switch housings, etc. The expense will be cost prohibitive just for fly by wire with cruise control. You are better off just getting a throttle boss or a new bike that has fly by wire with cruise control.
HA HA HA...
that's funny!
no seriously you cant switch to TBW... the sporty is not setup for that YET... use a throttle boss... much less headache
thanks for the input guys. definitely made me realize i didnt think this one through.
If you don't mind the look , I had these on my Buell a few years ago.
http://throttlemeister.com/app/inven...list/78-0.html
It's a cruise control and bar end weight to reduce the vibes also.
Just turn up the throttle while grabbing the end with your pinky.
It can be over ridden if needed or unset quickly if needed also.
It really worked well , not as slick as electronic cruise , but easier than the thumbwheel.
Mick
Mick
