Cranks, but won't start
Hello folks, been a while for me and yes I did a search before posting. Hoping someone can possibly suggest something I haven't tried yet before I just start buying parts to see "what works". I have a 2005 883xl. Bike right now cranks over but will not start. Last season bike ran fine. Did some mod's over the last few weeks. Swapped out mini-apes with 6 1/2" risers and replaced Arlen Ness Bicker Sucker with Force-winder. The risers forced me to extend the wiring harness for the tach/speedo combination. I cut, spliced, soldered and heat wrapped every wire one at a time to make sure I put wires back in same place, everything came on after I finished and checked (blinkers, etc)...so I don't think that is the issue, checked wiring schematics against manual just to be sure and it all looks good.
Here is what I have checked so far.
Spark is going to plugs, nice, strong and blue, pulled plugs and they do not look fouled.
Pulled tank off just to make sure I was not pinching any wires and to check to make sure I didn't jostle any other connections loose and to try my best to make sure there were not bare wires exposed and shorting anything out. Also checked wiring harness to make sure connecters didn't loosen and were all still seated correctly from previous wiring.
Yes the gas is on, and I pulled line and turned petcock on to make sure it was flowing. I may still pull filter out just to double check. I am also going outside now to drain the carb and then try to restart and drain again to make sure gas is getting to carburetor.
I did use new gas, however I guess it's possible there was some left over from last season, but would that cause only a crank, I would think I would get a rumble or hard start but who knows...
I did oil the new filter and let it sit for a day before I even tried to start the bike, is it possible though that oil got sucked in and that is causing it not to start? I should note I have been trying to start it now for about 6 days and nothing.
I did just replace the battery and it is putting out 12.7 volts.
I guess I am running out of ideas and once I check the filter and line I'm wondering if anyone has any suggestions? I should also mention I did do a diagnostic code check and every one was "none" and there were no stored codes from previously.
Sorry it's so long, but I wanted to give as much info as I could as I have tried troubleshooting a lot before coming on here, just looking for a little guidance or something I may have missed. Thanks in advance. Scott
To tell if you're getting fuel to the carb:
Remove the A/C, look into the carb throat and twist the throttle open. If you're getting fuel to the carb and the accelerator pump is working, you should see gas squirt into the throat from the brass tube that sticks up from the bottom of the throat with each (open) twist.
Just a quick update, I used some starting fluid and it started right up, stayed on for about 5 seconds. Won't stay running though, I'm thinking fuel issue. As I said earlier, when I turn the petcock on it does look like it has a steady flow. Any thoughts on if I should bother checking the fuel filter or should I just go right to the carb? Maybe jets are clogged?
Hey Cool Inferno, I'm assuming it was the carb. Pulled off the bottom and nothing but green hardened sludge. Just spent the last hour cleaning bowl, pulled jets and cleaned those. Hooked it up to the tank without the jets and let some gas flow through it to make sure it all got cleaned out. I did notice that the little black rubber accelerator boot is all damaged as well so I am going to take a ride over to a local shop and see if they have any in stock and then put it all back together and see what happens.
It's gonna sound kinda silly, but did you check the vacuum line on the back side of the petcock? I had the same issue after I buttoned up my 04 the other day and when I lifted the front of the tank to get to the turn signal plug I disconnected the vacuum line and it would crank but not start.
