Front running light not working
I have a 2011 1200C fully stock regarding anything electrical.
The right/front turn signal/running light is malfunctioning. Turn signal works fine. (All turn signal lamps work fine - front/back, right/left, all four flash.) Problem is the right front does not function as a running light as it should. Seems to be an intermittent problem as I recall having this problem after the bike tipped over last year. I replaced the bulbs and all was well.
Just noticed it yesterday, again, and went to dealer and purchased replacement bulb. New bulb didn't solve the issue. Bulb is good, even the "old" one is good. If I install the bulb "upside down", the running filament comes on. Of course, the bulb only fastens securely when "right side up".
I'm assuming the bulb is not making proper contact. I've looked through the service manual and the electric manual and couldn't find any useful info.
Short of replacing the entire right turn signal unit, any ideas or suggestion?
TIA.
TIA.
Yep. Figured that out after I posted. Gonna check the fuses today. If I can at least get my headlight back, I'll be good for awhile. Those front running lights don't do much good (in my mind) during the day. I rarely ride at night. Hopefully I can buy myself sometime.
Thanks. And, thanks to Guzzi for the link.
