Electrical Failure
Electrical Failure
Hi, Let me start off by saying I have a 2009 XL1200C and I recently bought new handlebars. I have a service manual and I am pretty comfortable doing my own work but I have had issues with these bars.
I got everything installed and tested (lights, horn, ect.) but during the test ride my turn signals, horn and headlight cut out. The headlight was due to a blown lighting fuse and after replacing that and the accessory fuse I still didn't get any power to the horn or turn signal switches.
Since then I have removed the hand controls and checked for cuts or pinches in the wiring, replacing what was necessary as I went with a sauntering iron/heat shrink. Once everything was re-wired and back together I still was not getting any power to my turn signals or horn. Now when I turn the key to "on" it immediately blows my lighting fuse.
Any advise would be great. Thanks.
Hi from the UK and welcome to HDF. Your query is a common one after changing bars and is probably down to a wiring problem. You need to go over your work from scratch, preferably using a multi-meter, checking each wire in turn for continuity and any damage or cross-connection. There ain't any other way! If your bike was working fine before you started, it can be fine again after you sort out the problems that have been introduced.....
wcwinans
10-29-2019 01:47 PM
Hollywood Ball
06-09-2009 03:44 PM
