Clutch dragging
Clutch dragging
Seems my clutch has always been dragging just a bit. I put it up on blocks, started the engine, pulled clutch, then shifted into gear. With the clutch in the back tire spins. With the clutch still in, if I press the rear brake, the tire stops and stays stopped. However, if I let the clutch out, tire starts spinning, then pull the clutch back in, the tire stays spinning forever. The clutch never disengages the transmission.
I've felt that it just shifts too hard between gears as a result suspecting that the clutch never fully disengages.
The bike is about a year old, would this type of work be covered by the warranty? Is it normal?
This is completely normal for a wet clutch when the rear tire is off the ground. All wet clutches have some drag and the rear wheel will turn under this condition if it's off the ground. As long as the bike is not trying to move forward when you're sitting at a stop with the clutch in, it's fine.
If you want to check how much free play adjustment your clutch lever has, here is a good video on that.
As for the hard shifts, just about all Harleys shift hard between gears. Just make sure you are pulling the lever all the way in before you shift and get the timing right. Seen folks shift up at the same time they are starting to pull in the lever not giving enough time for the clutch to disengage.
Received 4,200 Likes
Couple of thoughts.
Sometimes you gotta hold your tongue just right when adjusting the clutch...it's as much by "feel" as it by an objective measurement.
The other thing is, even though a wet clutch will continuously spin the rear tire when disengaged, a primary that is just a bit over-full will give that dragging feeling, and can make shifting a bit clunkier.
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
