Modifying 2015 Iron 883
Hey all, I'm new to this forum and have tried looking through older posts for my answer but can't find it straight.
I have a 2015 Iron and looking to do some minor mods for now.. Vance & Hines Short Shots and Arlen Ness Big Sucker Stage I air cleaner for starters.
I know this pairing will definitely require a tuner or ECM reflash. I've looked into a few, Screamin Eagle Street Tuner, Vance & Hines FuelPack, and a few others I've seen on these threads, but I'm having a tough time deciding between the different tuners and which would be best for this set up.
Anyone with a similar set up or more knowledge about which tuner would be best I would appreciate any input.
Thanks
*I've also head a lot of negative comments about dealerships or the Screamin Eagle tuner tuning the bike too lean and potentially causing damage..anyone have experience having an HD dealer do the tuning or am I better off doing it myself.*
Thanks
It seems to be ECU Tuning season :-)
First off, DO NOT get the "stage 1 dealer download" - it's the biggest waste of money ever (I did not knowing any better, and got nothing out of it).
If you know you're only doing bolt-on parts and not throwing on any "hardcore" engine upgrades - I.e. Cams, port polish, etc...you technically will not need to fiddle with timing so focus on fuel management. The Power Commander is supposed to be amazing but if you don't need that I would go a different, more cost effective, purposeful route.
I have the Fuel Moto Micro Tuner - it's awesome. They have great customer service and have specific maps you can get for free that are specific to your modifications. For $199 it's a great mod and will make your bike run cooler, faster and have more power.
Welcome and have fun with modding your bike!!!
My understanding of the dealer download is that all it does it take the AFR back to the normal lean factory settings in the ECM (buy changing timing, etc)? This is because adding the stage 1 upgrades of pipes/AC will lean the bike out more than the Factory mandated EPA settings. Harley cannot legally change the ECM settings to the stock ECM richer than the EPA settings (can only adjust them back). Again, this is my assumption as to why people say it is not worth spending the money on the download.
That being said, the stock EPA settings while lean (the 2014/2015 Sportster AFRs are leaner than the previous years I am told) will not cause your bike to blow up or your bike to be damaged as long as you are back to the factory settings. So, while the Harley download is nowhere a performance increase, it will take your modified bike back to "stock" (which defeats the purpose of your mods...correct?). You can ride your Sportster until doomsday and it will be fine. BUT you are not taking advantage of the potential improvements available by going to a tuner of some sort. My 2014 48 is stock. I am completely satisfied with the bike's performance for my style of riding. I decided that this time (out of 10 Harleys I have now owned) that I am not going to go through the stage 1 or more route. Changes to my 48 are more for comfort and aesthetics.
So while the Harley download will put you back to factory EPA mandated settings with your mods (and the bike will be fine), you are not getting anything to help with your stage 1 upgrades so far. Get a tuner.
Welcome to the forums first of all
Not sure what you have considered yet but, Devin and Kevin both use the Power Vision and are 100% satisfied with it. One of the great things about the Power Vision is it is delivered to you with a Custom Map, for Your Bike, already installed in it. You can plug it in, load the new tune into your bike, unplug it, and be riding with the New Tune in 5 minutes. The PV also has the auto tune feature which comes in handy!
However, i would try and go with a Free Flowing Air Cleaner like the Outlaw 587 or the 636v, these Air Cleaners will allow you to vent externally, this way all of the hot, dry, oily air doesn't get back in. The good thing is even of you decide you like the look of the Arlen Ness Big Sucker better, you can still vent externally by using a Hose Style Set Up.
These pictures are of a Twin Cam engine, but will be the same concept for your sportster.
Kelsey
Kelsey
__________________
Cristy
FREE SHIPPING - ORDERS OF $100 OR MORE - LOWER 48 STATES
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
Cristy
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
cowboys1822
02-21-2013 02:52 AM
XcellMusic
10-30-2012 03:59 PM
Daddy_J
10-19-2012 05:37 PM
