Rocker Cover Leak
Old 05-11-2015, 12:05 PM
tloc1000's Avatar
tloc1000
tloc1000 is offline
Default Rocker Cover Leak
I noticed this leak today. The bike is a 2011 48 with about 6500 miles. I'm the 2nd owner. It looks like a gasket leak. Is this gasket a normal wear item or do I need to check deeper to see if it's a symptom of a bigger problem?
Thanks for all the help.
Old 05-11-2015, 12:46 PM
subguy's Avatar
subguy
subguy is offline
The rocker gasket leak unfortunately is "normal". Not all, but a lot of Sportsters leak there where yours is and sometimes in the front. But the rear rocker box cover is where most of them happen. Not a symptom of a bigger problem. Google or search this forum (and XLFORUM) and you will see that this happens a lot. Not hard to fix and replace with a better gasket.
Old 05-11-2015, 01:00 PM
JBrooks271's Avatar
JBrooks271
JBrooks271 is offline
I had the same leak in the same place when I bought my Superlow. It was a quick easy fix with a new gasket.
Old 05-11-2015, 01:08 PM
hemisportster's Avatar
hemisportster
hemisportster is offline
I had the same problem with my 07 1200 custom. In fact I replaced it twice with Harley gaskets and they didn't last long at all. My buddy had the same problem with his 08 1200
custom. I finally replaced the gaskets with Cometic gaskets and haven't had a problem since. These gaskets come as a set so I would recommend changing both front and rear while you have the tank off. It's actually a pretty simple job. Make sure you have the service manual and torque to the proper specs. Good luck.
Old 05-11-2015, 01:12 PM
screamn_eagle's Avatar
screamn_eagle
screamn_eagle is offline
its not just sportys....i have an 04 cvo electraglide. i bought it used about 6 months ago. it only had 3000 miles on it. i now have about 10k on her and the rockerbox in the rear cylinder is leaking. it happened to another 04 cvo that i bought new in 04....pretty common among harleys and a pretty easy repair.
Old 05-11-2015, 02:12 PM
tloc1000's Avatar
tloc1000
tloc1000 is offline
Cool. Thanks for the info. I should have some time to fix it since the forecast is rain for the next 10 days.
Old 05-11-2015, 05:58 PM
jimmymiko's Avatar
jimmymiko
jimmymiko is offline
Just did a video on how to do it, not the best quality but I documented the whole process.
Old 05-11-2015, 08:15 PM
tloc1000's Avatar
tloc1000
tloc1000 is offline
Harley Sportster XL883L Rocker Box Upper and Lower Gasket Replacement - YouTube
That's awesome. Thanks!
Old 05-15-2015, 10:48 AM
Shek's Avatar
Shek
Shek is offline
6th Gear
Greetings from India. Great job with the Video buddy . I had a similar problem with my iron 883 after putting the aftermarket chrome rocker cover trim on my heads. I was told by my Harley service guy that its the size of the rocker cover screw that causes the oil leakage and then i had to remove the covers so that the leakage does not happen again. And guess what ?? just few days after that i could see the leakage yet again so i presume i have the same gasket issue.
Attached Thumbnails Rocker Cover Leak-20150405_180920.jpg   Rocker Cover Leak-20150503_105509.jpg
Old 05-24-2015, 05:44 PM
tloc1000's Avatar
tloc1000
tloc1000 is offline
I ordered a Cometic gasket kit and finally had some time to install it. While I had everything apart, I relocated the coil and ignition and did a wire tuck.
Attached Thumbnails Rocker Cover Leak-iphone-022.jpg   Rocker Cover Leak-iphone-020.jpg   Rocker Cover Leak-iphone-025.jpg   Rocker Cover Leak-iphone-028.jpg   Rocker Cover Leak-iphone-031.jpg
Quick Reply: Rocker Cover Leak
