Tips On Airing Up Touring Shocks
Old 05-07-2015, 06:43 PM
Luckster's Avatar
Luckster
Luckster is offline
Default Tips On Airing Up Touring Shocks
Hey everyone I am in the process of finishing up the touring shocks on my Nightster. I figure I can get some advice from the people that already have them installed. Whats the best way on putting air in the shocks? I know HD makes a pump for around $50 or so but if there is a cheaper way I am all ears. Thanks for any info!
Old 05-07-2015, 08:53 PM
Cool Inferno's Avatar
Cool Inferno
Cool Inferno is offline
Check out this thread from the touring section. Its an old thread but it may help.
https://www.hdforums.com/forum/touri...ir-shocks.html
Old 05-08-2015, 01:08 AM
Luckster's Avatar
Luckster
Luckster is offline
Thanks!
Old 05-08-2015, 09:51 PM
lh4x4's Avatar
lh4x4
lh4x4 is offline
Small bicycle pumps at a Trek or other bike shop will have some about 8 inches long that will do the job for about $15.
Old 05-08-2015, 10:00 PM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 31,047 Likes on 11,648 Posts
Don't you need to use HD certified air?
But seriously folks...you probably should get a pump with a gauge installed. And it should be very low capacity. Air shocks have very low capacity, and are easy to overfill, and destroy. That's what is nice about the HD pump: built in gauge, air release, low volume, and it provides HD certified air.
Old 05-09-2015, 05:38 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,868 Likes on 2,430 Posts
I've used a short bicycle pump for the last 25 years, with a cheap low pressure pencil gauge (from my off-road days). That was just making use of stuff I had to hand. There are alternative pumps available similar to the Harley pump which are a bit cheaper, look on Ebay for a 'PRO Motorcycle air shock pump'.
Old 05-09-2015, 09:27 AM
LonestarXL's Avatar
LonestarXL
LonestarXL is offline
Check eBay, I see used HD pumps on there cheap sometimes. I love mine because of the gauge and the fact that I can take the hose off without releasing air. The little button to let air out while it is attached us really handy too. If there's another bike type pump out there that can do all that I would get it.
Old 05-09-2015, 12:47 PM
Luckster's Avatar
Luckster
Luckster is offline
Thanks for the replies!
Old 05-09-2015, 05:13 PM
gar187er's Avatar
gar187er
gar187er is offline
I ride at zero psi. no pump for me!!!
Old 05-09-2015, 08:27 PM
Rollbar's Avatar
Rollbar
Rollbar is offline
Quick Reply: Tips On Airing Up Touring Shocks
