48 suspension upgrade
I am looking to upgrade my suspension and possibly change things up quite a bit on my 2014 48. I'm thinking either 12", 12.5" or something even more dramatic. Question is, will 12 or 12.5 change the geometry of the bike too much? If I went even taller and also raised the front end to even it out some while cafe-ing out the bike what are some things I should be concerned about?
Thanks!
Thanks!
HTH.
I did something similar to lewk.
13" Electra Glide rear shocks and Roadster damper tubes for a 2" lift from stock.
Doesn't look as cool , but my spine says "thank you" every time I hit a pothole.
Here's where I got my inspiration.
http://xlforum.net/vbportal/forums/s...d.php?t=944857
Mick
Mick
Everyones got it right. It wont look as "cool" to some but who cares? Only raising the rear will make it steer quicker and have a little less stability in higher speed straight runs. Best to raise the front too. Many use damper rods from a standard or roadster. The only issue with that route, and its not that big of an issue, is sourcing the parts. This would be the time to upgrade your springs, seals and such for better performance. The easiest way (I think) is getting monotubes from progressive for a standard. Last year of the standard was 2008 so just use those. Progressive says they wont fit a 48.........they will. Easy to do, take your old stuff out, drop in the new, no damper rods, springs, spacers or seals to source or deal with.
This is how much it will raise your forks.
Ditto. Raising the rear only will give you quicker steering, which is nice in the twistys!
__________________
🚀 Grab a Chance at a $500 Refund! Click HERE! This DK Special ends 10/22/24 🏍️
DKCustomProducts.com
http://www.progressivesuspension.com...-series-shocks
I wouldnt say they are day and night difference but very noticeable.
I weigh 175 and went with the 12.5's to get the softer spring rate and I say they are worth it.
from Progressive :
"The 12.5" shock is a bit longer so it can use a 75/120 lb./in. spring, and the 12" shocks have to use a 90/130 rate spring because they are a bit closer to the bottoming point. The 12.5" shocks will have the softer springs and more travel for a more compliant ride quality."
