handle bar change
I'm not sure what mad chemist is talking about as far as turning a 1/4 turn. But on mine I put on some 9" narrow apes I made. I took the stock front brake line into my local hydraulic hose shop. They cut off the rubber section and crimped on a new longer rubber section. They pressure tested it and through in a couple crush washers and I was out the door in about 15 minutes for about $25. I also had to cut a couple zip ties holding my control wires in place to loosen them up. They had plenty of length.
http://www.ebay.com/itm/Sportster-In...item35e7d00f3d.
Check this guys bars for Sporsters. This link may not fit your bike, but I am sure he has some that will. I am not a mechanic, but a part changer with service manual in hand. Hope this helps.
