Slip ons are POPPING
Old 04-08-2015 | 12:54 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Decel popping does Not damage your engine...it is simply unburnt fuel that is burning in the exhaust tract after exiting the engine.
Decel popping occurs when one of two things are present.
1. The bike is so lean the exhaust is superheated and is burning the unburnt fuel that is in the pipes (there is always some unburnt fuel in the pipes no matter how lean). This is very rare.
2. The AFR IN THE pipes is just right to burn the unburnt fuel. This is quite a common occurrence when free flowing pipes are installed (whether or not a free flow A/C is installed). It can also occur if there is an exhaust leak that is introducing extra air into the exhaust tract.
Also, check for intake leaks at the air cleaner and at the intake manifold/heads.
One way to change the AFR IN THE Pipes is to install Thunder Torque Inserts.
If you don't like decel pop, and don't want to change the AFR in the pipes by changing the baffles or adding Thunder Torque Inserts, It is absolutely possible for a tuner to richen it up a bit or lean it out a bit to change the AFR in the pipes resulting in little or no decel pop.
HOWEVER, the methods used to tune the decel pop out of very open pipes are almost always at the sacrifice of performance and/or MPG.
Just because there is no decel pop does not mean you have the best performance tune, AND just because there is decel pop does not mean you have a bad tune.
An open pipe with the best performance tune is almost always going to have decel pop.
Conversely, it is possible (but very rare) to have a good performance tune & open pipes and not have decel pop. This almost always requires some fine tuning with a full flash tuner like a TTS, Power Vision or HD Race Tuner.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Old 04-08-2015 | 09:03 AM
Milkman424m's Avatar
Milkman424m
I have the vance and Hines FP3 installed on auto tune mode. Helped greatly! Working on ordering a stage 1 intake kit as we speak.
Old 04-08-2015 | 02:12 PM
Gibbsey's Avatar
Gibbsey
I installed Vance & Hines slip on and it popped like crazy on decal. I tightened everything according to the manual. i sent for quite baffles and once installed no more popping. Only and occasional small one which sounds cool.
Old 04-08-2015 | 05:24 PM
Wi_Duker's Avatar
Wi_Duker
S&S Slip ons.
no exhaust leaks
no intake leaks
Bike is not running lean
pop pop pop
Old 04-16-2015 | 08:59 AM
Milkman424m
Originally Posted by Wi_Duker
S&S Slip ons.
no exhaust leaks
no intake leaks
pop pop pop
Get a fuel pack-
Old 05-06-2015 | 11:57 PM
hscic's Avatar
hscic
Originally Posted by Guzzi
The FM Micro plugs directly into the injectors, another wire taps into the Throttle Position Sensor, and one connects to the battery. Also O2 eliminators are used.
Mine is velcroed to the side of the battery. It's a very small compact unit.
http://www.fuelmotousa.com/pdf/micro/FM-019.03.pdf
Thanks Guzzi, I read in another thread that there were two ways to install, remove the tank or lift the rear portion of the tank. Not sure if this applies only to specific Harley models. Did you need to lift the tank?
Old 05-07-2015 | 01:15 PM
Guzzi's Avatar
Guzzi
Did lift the tank and used a long pair of needle nosed pliers and a long cotter key extractor to help with the connections. Long skinny screwdriver can be used in place of the extractor.
It was about a 2 beer job.
Old 05-07-2015 | 02:08 PM
hscic's Avatar
hscic
2 beer job...lol. I think it depends on how much beer you can handle. Thanks for the info. Fuel management is my next project so just researching different options and skill difficulties.
PaulFLHTC
08-25-2015 07:37 AM
surfnorthwest
2014-2023 Touring Models
07-26-2014 03:18 PM
AZfatbob
04-16-2012 02:12 PM
RebelGlide
05-23-2011 09:49 AM
BIGDADI
03-06-2009 01:44 AM
Quick Reply: Slip ons are POPPING
