09 Nightster Starter Issues
Correct. I pulled the relay out, and it didnt do it. Then I pulled that nut and connector in the last pic, and it didnt do it. I hooked it back up, and its doing it again. I thought about replacing the switch, but I cant figure out how to get the wires out of the housing. I was messing with it while I had it apart to replace the idle cable. This F&$?! issue is consuming my life right now.
thats because that nut is what powers the starter. it wont turn disconnected. If it stops by pulling the relay the trouble is upstream of the relay. it probably wont do it if you nip the green/tan wire at the relay. that will prove its toward the frame wiring or the handelbar wiring.
If you want to ride, nip the green/tan wire , ground the relay side and go.
Now if its gone trouble is in the TSM if it still does it, trouble is in the wiring or the handelbar switch
put everything back together and remove the screws from the switch housing and see if it does it now. If it was fine before you did the cables, then something got pinched.
