Oil Cooler install write up
Old 03-19-2015, 06:51 PM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,199 Likes on 1,685 Posts
Default Oil Cooler install write up
I finally have all the goods i need (outside of a dremel) and will install over the weekend.
I know this post will drive the anti-oil cooler folks insane.
Part#:
HD
62996-07A- Premium Oil Cooler Kit for Sportster Models
63087-07 Chrome Oil Cooler Cover
OIL!!!!!!
JAGG-
4700 Offset Oil Filter Adapter with Automatic Thermostat
211-JSSN06 Stainless-steel Braided (SILVER) kit
CL138 - 1-3/8" frame clamp
no # JAGG Anti-rotation Device for Offset Oil Filter Adapters
no # Looped T-handle Hex Key Tool
unsuspecting bike
sportster xmas
oil cooler, adapter w/ thermostat, anti-rotate device, mounting clamps, and tool
hoses: hd crap and braided jagg goods
braided jagg goods
hd crap
oil cooler and cover
jagg clamps
hd clamps
anti-rotate device
xl1200 cooler
xr1200 cooler
oil!!!!!!!!!!!!!!!!!
Old 03-19-2015, 08:36 PM
5wheels's Avatar
5wheels
5wheels is offline
am interested to see how this works I have a 03 with the 883 that runs very hot. it has a dft trike kit on it that runs the weigh up to around 800 pounds.
Old 03-20-2015, 12:25 AM
mopeman-72HD's Avatar
mopeman-72HD
mopeman-72HD is offline
Me too...subscribed!
Old 03-20-2015, 12:55 AM
starforbrian's Avatar
starforbrian
starforbrian is offline
Can't wait! I'd like to install one on my bike when it comes time to change the oil again.
Old 03-20-2015, 05:34 AM
BensonUK's Avatar
BensonUK
BensonUK is offline
love it when people step outside of the box....watching with interest
Old 03-22-2015, 09:48 PM
cvaria's Avatar
cvaria
cvaria is offline
Smile done!
Bike grew wngs
Trimmed braided hoses (first go round). taped the area to cut and used the dremel tool with diamond cutting disks. could have been done a number of ways but, i need a dremel tool anyway for my jeep (rust abatement), purchase justified.
moved cables to find a good place to mount the clamps
tested a few positions, opted to place the cooler as high as possible make adding the hoses easier later on since they don't have the flexibility of naked rubber.
got nosy and found a rust issue
i'll replace it later... clutch cable F***ery is not on the critical path.
Old 03-22-2015, 10:00 PM
cvaria's Avatar
cvaria
cvaria is offline
test fitted the xl1200/883 cooler to better judge the length need for cables and the adapter
pulled the oil filter (to get commitment from myself to the job)
began fitting the adapter. it must be disassembled to mount it on the bike.
all apart (only 5 little bolts)
mounted and adjusted. that bolt is a 1".
added top portion and anti-rotation device (aka cheap piece of scrap metal that stops the thing from spinning when you are removing oil filters)
retrimmed hoses, finished them with pretty worm clamps. added oil to the insides and mounted them.
Old 03-22-2015, 10:29 PM
cvaria's Avatar
cvaria
cvaria is offline
added pointless cable coupler just to make myself feel better about wasting money on the entire kit when i really just needed braided hose and pretty worm clamps.
There's no way i could have know that though.... but you now know.
test fitted the cover.
for the cover adhesive, the directions called for Harley-Davidson® High-Performance Sealant - Gray - (read: RTV) - 99650-02. i subbed permatex Ultimate gasket maker because..... it was in my chemical stash, and even though the HD RTV is rated to 482 degrees and the permatex is on rated to 400.... if 400 ever happened on the cooler, i'd have other exploding engine issues that would take precedence over a loose oil cooler cover.
rtv'd cover attached
added a fresh filter. i will change all the oil after i test ride and check for leaks. all done.
clean looking. i could have trimmed the hoses a little more for a cleaner look.. but it's a PITA to trim them. life goes on.
damn mess
Old 03-22-2015, 10:48 PM
cvaria's Avatar
cvaria
cvaria is offline
Old 03-22-2015, 11:21 PM
cvaria's Avatar
cvaria
cvaria is offline
if you are wondering where the XR1200 cooler went, see here:
https://www.hdforums.com/forum/harle...l#post13803587
Quick Reply: Oil Cooler install write up
