Oil Cooler install write up
Received 2,199 Likes
Its permatex part#29132. should be on amazon
The hoses might be an issue because of the stress they are putting on the cooler nipples. That may change after i run the bike a few times. That braided stuff is mean but, the hoses would be exposed and unprotected otherwise. Catch 22
Thanks.
Or you could use wire loom over the lines. Small one that is tight and then one size up.
Could even put a 45* brass fitting in there. That also would help if you have to take the cooler off-just remove it from the 45* fitting. Not sure how it would look.
Just a thought, and thanks,
Jim
Jim
Thanks.
Jim
Jim
i don't think the site does. i added the thermostat that kicks on and off at 210 degrees. i can feel when it activates. my left leg gets warm.
i just installed it because it gets ridiculous down here in the summer. i may add the fan later. http://www.jagg.com/fan-accessories.html
cvaria, thank you very much for the write-up and pics. A Jagg Slimline is definitely up there on my to-buy list. Did you seek out any other mounting points for the oil cooler before installing it? Alongside the downtube is a very effective place for it but I'd prefer to tuck it out of the way a bit more if possible. Between the downtubes, laying horizontally ought to work, right?
There are other alternatives to the $400 Jagg coolers. Oil coolers can be had for $100 - $200 if you look around and there are many different designs/setups; however, the Jagg is certainly proven effective.
