Anyone else had this problem ?
05-1200c been running great for the last year , but this morning after 15 miles acts like its running out of gas . pulled over Idles fine but will only run at low speed . Able to pull the choke and nurse it home under half throttle overflow vent is clear , could the problem be in the gas shutoff - screen - vacume- or trash in carb- will be the weekend before I can deal with it . Any tips or hints will be much apreciated . Thanks
RE: Anyone else had this problem ?
I personlly have not had that problem, but I have heard that other have had problems with the petcock. Its vaccum operated, which just begs for trouble. Everyone seems to switch to the Pingel Valve, which I will be doing.
This MAY be the problem you are having. The symtoms seems the same. Let us know what you find out.
Got-er-fixed , ran a free flowing gas line into carb through a funnel , still had the problem . Then I ran some SEA-FOAM into carb Killed it let sit a few minutes . When I cranked her back up the gunk in the carb was cleand out . Test ride went great now I can get some sleep tonight, glad I didnt have to tear down the carb .
