Replacing gas tank question
Tried searching did not find the answer. I am replacing my gas tank on my 48 this weekend with a larger tank.
Question is when I swap out the gas tank should I get a new gasket for the fuel pump or can I use the same one? Bike is still fairly new 2013 with 5K miles.
Guessing that is why HD sells this kit? This tube that comes with the kit seems to be a shorter vent tube?
http://www.harley-davidson.com/store...-15-6299907--1
When I got my 48's tank changed to a larger 3.3 I went ahead and got a new gasket. Being non-mechanical, its was explained that removing a gasket is like when you unseal a jar. So, I got it. I didn't need to get anything else for the swap. Now, whether or not the dealers reasoning is correct or faulty, I'll leave it to you gentlemen. I did it just to be on the safe side. I love the larger tank.
