nightster fuel light concern...
RE: nightster fuel light concern...
Lucky you. I want a Nightster so bad. Still saving up the cash though. I don't want to finance. Anyways, I've been cruising the boards and this is what I've found. The light will come on after 80 or 90 miles. Second thing I've heard is to make sure the bike is upright when you start it after refueling. Range on a single tank is around 130 plus or minus miles. On my sport bike I go by the odometer. I use the light as a reminder to check my current mileage.
Wait, why does the bike die at 132.5 miles? Isn't the tank 4.5 gallons for '07 Sportsters or does the Nightster have a different tank size? Thats well over 200 miles before fill up? But I have a 2007 1200C and my light comes on after 1 mile. They say I need to get on the second tank, I just bought it and this is still my first tank, and see if that fixes the problem.
ORIGINAL: totalgeek
Try this...
If you want your low fuel light to more accurately reflect a low fuel situation, don't turn the ignition on until you've got the bike off the side stand and standing straight up. Once you've got the engine running, you can put it back on the side stand until you're ready to ride off.
Mine seems to like to come on at 85 miles regardless of actual fuel level ... I give up. My guess is the sensor only needs to lose fuel contact once and then it is programmed to stay on. So if you lean on a turn and fuel moves away from the sensor it will trigger on and stay on even if the fuel level comes back up.
The Nightsters could use about a 4 gal tank, that would make me happy. I have to fill up about every 2 1/2 days of commuting. I get great gas milage (45 mpg) but still it seems like I am always at thegas station.
