exhaust mods-patriot & thunderheader
looking for some input. I have a patriot exhaust has anyone removed the butterfly valve or secured the the lever on the outside to not rattle?
For the thunderheader exhaust has anyone bent the taps on the inside & has it made a noticeable difference in the lower rpm range?
Received 4,197 Likes
TTI Link HERE
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
No experience with the Patriot. We have had quite a few folks use the Thunder Torque Inserts on the Thnuderheader to get a good bump in the low & mid ranger power...seems there is a flat spot/dip that the TTI's take care of.
TTI Link HERE
TTI Link HERE
IF I go the thunder torque route and remove my baffles, use the inserts - will I get BOTH a bit of a louder sound and increased power in the midrange? I'm trying to find the right combo here.....I know with the VH you have to drill to get the inserts in so I wanted to make sure I made the right decision. Thanks!
Im not a believer with bending the th tabs. I had the defender pipe flapper mounted soild on the outside with a sliver of metal. Finally cut the damnthing out. Sawzaw!!!! last, ive been running the defender with a straight pipe shoved inside of the collector. nastier sound and zero performance loss at any rpm. ive own both pipes
