cannot get headlight out of bucket
Thanks guys, sounds like you've been there, done that, I will have another go at it. My running lights go through there and they are flickering off and on, must be a loose connection. I would also like to install brighter bulbs while I am at it. The way the running lights are wired, when I turn the high beam on the running lights go out. Wouldn't it be be better if they stayed on?
WD 40 and small screwdriver worked great. Found a loose connection causing running lights to go off and on. Now I am ready for some brighter bulbs. Have you got any recommendations? Do the brighter bulbs pull more or less amps? I am wondering if my present wiring is good enough for brighter bulbs?
If the bulb is the same wattage as the stick bulb it'll draw the same amps. Wattage/12(v) = amps.
Pathfinder and Cyron make LEDs with no ballast (built in) that will fit in a 5 3/4" headlamp casing. It draws much less than a halogen bulb and obviously much brigher. PIAA makes a halogen that is much brighter than stock (almost like LED) and draws the same as the stock halogen. I had the PIAA but currently run the pathfinder on my 2011 Sportster Low but someone in the forum indicated that Cyron cost less and is the same thing.
Here is a link to a previous discussion.
https://www.hdforums.com/forum/sport...headlight.html
Wakko47
02-17-2013 01:21 PM
