Driving lights
Driving lights
hello I was looking for something similar to the below link any suggestions, comments, experiences would be greatly appreciated
I'm looking to mount this at the front fender bracket on a 2013 Sportster custom
http://www.cruisercustomizing.com/piaa-powersports-005-lamp-kits-with-multi-fit-mounting-brackets/part/PIAA-74222
thank you
thank you
Received 4,193 Likes
I've run with driving lights off the forks before. Really makes a nice difference.
With the cost of very effective headlight bulbs coming down, I've found it more economical to get a great headlight "bulb" and get the same, or better, coverage than adding driving lights.
We have been in the process for awhile of testing different aftermarket bulbs. We should have a good variety of replacement headlight bulbs available in the next month.
These guys make some really nice (expensive) lights.
http://www.motolight.com/product/Fen...%20Light%20Set
I've seen them in action and they look great from the "other motorist" point of view.
Definitely a safety enhancing mod.
Mick
Mick
I just followed your link, also searched separately for their website and got blocked by my Kaspersky s/w, so take care.
yesterday evening another rider showed up with these installed on a Sportster, they looked great
like I mentioned earlier I was looking to install them on the front fender mount , rear bolt
any suggestions on wiring with a 2 pole switch straight to the battery, grounding placement, etc would be greatly appreciated
http://mobile.walmart.com/ip/Optronics-55w-Pair-Driving-Light-Kit/16680058
i've been running the H.D. oval crash bar light,s for about 100,000 miles, on my '06 "R". They mount off my adjustable highway pegs. Removing the top clamp use its base as a pattern transferring to a piece of bar stock. A holed centered on the bar, drilled and tapped to fit the peg bolt on the pegs will secure it to the bike and allow for L to R adjustment. You can loosen the allenhead bolt that secures the peg to gain vertical adjustment. Thes give me great side shoulder illumination but more importantly have made me much more visible to cagers. Since the install I'vee not had any idiot pull out in front of me.
(tip: make a wiring diagram when you're finished and put it in your service/repair manual. You won't remember how it's wired 6 months after you do it.)
The power block in this picture is something that I added, it's not part of the Kuryakin kit.
karz10
09-17-2012 11:23 AM
moose1982
05-04-2011 01:04 PM
