Looking for good baffles for my SE pipes
Try Dennis Kirk:
https://www.denniskirk.com/4403296.s...utm_medium=cse
Just make sure the diameter is correct for your muffler.
If you're looking to quiet it down a bit you could go with something like the Thunder Torque Inserts, they will give you a lower deeper tone. Thunder Torque inserts are designed to perform well when used on slip-ons with and without baffles. You can adjust the Thunder Torques to get it to the sound that you like best.
Here is a video of 5 bikes with the Thunder Torques installed.
Kelsey
__________________
Cristy
FREE SHIPPING - ORDERS OF $100 OR MORE - LOWER 48 STATES
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
Cristy
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
Seeing as you don't have any right now , anything should work pretty well.
These are fairly popular.
http://www.cycle-shack.com/cycle/ago...ANCE%20BAFFLES
Kelsey might have what you're looking for , you should already have the holes for them.
Pretty hard to go wrong for $19.00 ....
Mick
Mick
Mick
Mick
Yeah I believe I'm going to give the DK's a shot first since they look fairly easy to install after I make the original baffle mount point larger. If I need it quieter I may go with the baffles you mentioned.
My bigger concern is that I will have to get it tuned again and spend a lot of money just to make it quieter. The bike was tuned with a power commander by the previous owner already. I'm especially concerned because I want to get a DK air cleaner too that does not revert the motor air back into the breather. I'm hoping that alone wont need a retune.
If you don't already have it tuned for a Stage 1 Air Cleaner System, then you would need some type of Fuel Management, you could go with something like the XIED's for more of a budget solution.
Kelsey
Location: In the foothills of southwestern NC - US of A
Sell the SE's and buy a set of Khrome Werks 3" HP+ slip-ons, they've got a great deep rumble but are NOT obnoxious. Then bite the bullet and purchase a Power Vision tuner that you can use to auto tune whatever your intake/exhaust combination may be, all by yourself, to have a great sounding and running bike
I assure you, you will not be disappointed in any respect whatsoever with the combination!
=8^)
=8^)
first thing is you will prolly not need a retune until you change the ac....second the retune you can do yourself..if it has a power commander, just call fuelmoto and they will walk you though it and even give you the proper map for your set up.. fuel moto will email the map to you and you just take the power commander and plug it into your computer and download the map into it...
=8^)
=8^)
Same thing for me. Previous owner gutted the SE pipes on my FLHRS and it was way to loud and "hollow" sounding. Absolutely no low end torque.
I put a set of 2" Rush baffles in and it now sounds like it should big and low. And low end torque feels great now.
http://www.rushracingproducts.com/bafflekits.html
You should call to verify which set is for your mufflers.
Here is a set of videos that gives and idea of the sound (real life is louder that the videos BTW)
BTW, if you go to the youtube link, you can watch videos for all the baffle sizes.
