Calling All Sportster Baggers...Post Pics of your Bagger
#531
I relocated my stock turn signals...my bags are RBT when they are on the bike.
Close-up so you can see the mounts. Have quick release mounts for my sissy so had to use longer bolts.
This is the J&P Cycle relocation kit that I am using. Just remove the turn signal from the fender, install on license plate kit, and reroute the wires to the turn signal connectors in the tail light. Hardest part is removing the turn signal from the fender since there is a nut inside the strut cover holding the turn signal.
I think if I go this route I will buy the HD relocation kit. I would like to keep the rear turn signals for when i wouldn't have the bags on the bike.
Thanks!
#532
Love my bags...beats wearing a backpack or strapping things to the fender lol? You came to the right place as this is a bagger thread.
Good luck!
#533
Took the bike out for a short run on surface streets...as expected, much better. No direct airflow from the 9.5" flared WS hitting my head/face. Still get breeze which is wanted, but no strong stream of air off the WS that I was getting with the 10" straight and the 8" flared.
Update 2/26/16: Took the bike on the freeway and it was better but there is still some airflow...but not too bad. I think if I go taller, will need light tint for lower view. If I bring down my helmet visor, its all good. So will probably leave it.
#534
No problem....glad to share. Just providing another option for rear turn signal relocation kit if you find HD's relocation kit doesn't work for you or too pricey.
Good luck!
Good luck!
My autobody shop said it may be a pain to paint them with the hinges on there, unless he can disassemble the hard bags.
#535
Update 2/27/16: Just dropped off my oil and battery covers for painting and asked my painter about the disassembly of the hinges on hard saddlebags....answer: YES he removed the hinges. He said it is easier to paint if removed. There are 8 torque screws holding the hinge and 2 holding the cover. He said it is simple to remove.
#536
If you have a Sportster Bagger, please share your pics. Would like to see what kind of baggers are out there and what you did to your ride. I realize "baggers" are more common in the touring world, but just checking the Sporty community in hopes of finding a new generation of Sportsers and bringing this specialized group together to collaborate and share ideas.
Here is my Sporty Bagger...2011 Sportster Low XL1200L
#537
Thanks much!...wow you reply to posts from the beginning..lol. Here is a more recent pic. but as mentioned above sent a set battery and oil covers to the painters to color-match.
Share some recent pics of your bagger
#538
Actually not sure if he disassembled to paint...I just took my bags out of the box to my custom painter. He disassembled and reassembled whatever was needed to properly paint the bags. My painter specializes custom painting for motorcyles (he even does a lot for the local Harley dealership) so he has no problem with disassembly. I do believe he would removed the lids to paint. I do know he disassembled and reassembled my fairings for painting since I was there when he was reassembling it. Perhaps your shop is familiar with cars/trucks not motorcycles.
I think I will order these primed so they will be ready to paint!
#539
