Would those of you that are more knowledgable than I am please tell me if a 2013 Iron tank is interchangable with a 2008 Roadster? I'm assuming mounting is the same, but what about the fuel pump/petcock/connection? Anything else I should be aware of if I am swapping tanks onto a 2008 Roadster?
should be the same and fit. only fitment issues I could think of is if you went with the 4.5 gal tank...which will bolt up but the seat wont fit. iron uses a 3.3 gal tank and the roadster does as well
