Warped SE Air Filter Backplate
When I installed this kit, I followed the instructions to the letter. After I completed the installation and inspected my work, I noticed the backplate is noticeably warped (it was straight before I installed it). Is it normal for the backplate to be warped after installation? I thought it was a little odd that the instructions stated to torque the air filter to the backplate (using 60 in-lbs of torque). I noticed it took quite a while beforeany torque registered on my torque wrench (I only torquedthe filter boltsto50 in-lbs). It seems to me that 60 in-lbs was excessive, given the visual evidence and the filter should have just been snugged to the backplate. My question is, should I loosen the filter now, or is the backplate permanently warped? Is this a common problem with this air filter kit? Thanks. CG
jac737
10-04-2018 12:18 PM
