Air filter help?
Received 4,197 Likes
External breather system looks like the DK Custom Traditional Hose & Filter set-up that you can see at this LINK.
The air cleaner is a bit restrictive, but far better than stock.
You can see top performing air cleaners at this LINK.
However, the one pictured will work fine unless you do a lot of high RPM riding, which is where it will starve out a bit. Make sure to keep it clean and it will do a good job for you.
