Battery Charge
Old 11-29-2014 | 03:59 PM
D Nuts's Avatar
D Nuts
Default Battery Charge
I read a few threads and still not confident an approximation on how long a battery should hold a charge while idle in cold weather (its been about average 0 degrees celsius for the past 2 weeks). I think the last time i rode my bike was about 3 weeks ago. I tried to start it up today and the bike would turn, but not enough to start. Essentially, IM trying to find out whether i should go buy a battery now because i have a rare opportunity to ride tomorrow as the forecast is a balmy 10 degrees celsius. Temps will drop immediately thereafter. I have it on the tender of course, but if the battery discharged too quickly, Id rather just buy a battery today before the shop closes. having said its been about 3 weeks since i started my 2014 48 only has 660 kms on it. Should the battery held its charge? thanks
Old 11-29-2014 | 04:52 PM
Guzzi's Avatar
Guzzi
My 2014 Battery just died a couple of weeks ago. Dealer replaced it under warranty.
Since the weather will be good tomorrow buy a cheap charger and charge it overnight.
If it doesn't hold the charge after a couple of days get it replaced under warranty.
Old 11-29-2014 | 05:05 PM
HKMark23's Avatar
HKMark23
Last winter I had my battery on one of those $35 Princess Auto battery tenders. It worked like a charm. I'd suggest you get one of these even if you end up getting a new battery. It apparently, (I have no amount of personal experience in this), lengthens the service life of your battery.
Old 11-29-2014 | 05:34 PM
D Nuts's Avatar
D Nuts
thanks. i have 3 trickle chargers from my race bikes and Ive never had any of those batteries ever failed me. it started after being on the charger for 2 hrs, but i just wondered how long it should last. i didn't know my warranty covered the battery, but good to know. my warranty is good tiil fall 2015. i may extent but its pretty expensive i think (thats a whole other story and maybe a good post to explore). thanks
Old 11-29-2014 | 06:18 PM
grbrown's Avatar
grbrown
Use a tender, just as you do for your racers. It's easiest to simply buy another one, plug it in and forget it, alternatively connect one up every couple of weeks.
Old 11-29-2014 | 09:11 PM
nightstermass's Avatar
nightstermass
Set up a quick disconnect on your battery if your not riding put it on a tender. Always do it and youll battery ill last longer
Old 11-29-2014 | 10:31 PM
D Nuts's Avatar
D Nuts
yup, have the quick connect on the racers and my 48. I put all my bikes on the tender during winter. i was just wondering how long a 48 keeps its charge. ill be using my tender on my 48 all year round
Old 11-30-2014 | 06:08 AM
HKMark23's Avatar
HKMark23
Search around the forum. There is at least one fairly lengthy and, occasionally animated, debate about extended warranties. I'll make a couple of points here. Some seem to think the EW is for maintenance, "do my own wrenching", its not. Some think its a warranty, its not. Its insurance, a bet against your bike remaining trouble free for 5 more years.
Old 11-30-2014 | 06:12 AM
Jackie Paper's Avatar
Jackie Paper
A 2014 battery should hold it's charge a month if it's fully charged. Key is was it fully charged. In that kind of weather, would not hurt to keep it on the low amp maintenance charger.
Old 11-30-2014 | 07:05 AM
Iceman24's Avatar
Iceman24
^^^Yes^^^
Depending on the temp too...batteries should retain enough juice, but a month's pushing it. Put it on a tender and you never have to worry...
Quick Reply: Battery Charge
