Why chain drive ?
Old 04-14-2007, 08:02 PM
HOTLAP's Avatar
HOTLAP
HOTLAP is offline
Default Why chain drive ?
I have noticed that some people convert to chain drive and I'm not sure why. From the first time I saw belt drive I thought it was a huge improvemant over chains, I am happy not having to lube the chain then clean all the lube splatter off the wheels & side of the bike, am I missing something?
Old 04-14-2007, 08:37 PM
128auto's Avatar
128auto
128auto is offline
Default RE: Why chain drive ?
Very simple, an old school look. Right Balley?
I don't want to lube the chain weekly so I stick with drive belt, almost no maintenance.
Old 04-14-2007, 09:06 PM
HD7585's Avatar
HD7585
HD7585 is offline
I run a chain because my bike is so dam old. The new hi tech lubes of today are dry after 10 minutes when applied. With these lubes,my chain runs as clean as a belt.This stuff won't even get your fingers dirty. A friend of mine kicked up a stone with his belt drive sportster and it went between the belt and the pully and shredded his belt. I would say thats at least one plus for a chain. And the look , ya can't beat the look
Old 04-14-2007, 09:25 PM
markdt's Avatar
markdt
markdt is offline
A lot of people with sportsters change to a chain to be able to put on a wider tire.130-150 Unless you are running 150+ hp and need to , it's all for looks. mark/.
Old 04-14-2007, 09:51 PM
Zeb's Avatar
Zeb
Zeb is offline
It's interesting to note that the first Harley's, if I remember correctly, were all belt drives.
Old 04-14-2007, 09:55 PM
balley's Avatar
balley
balley is offline
Nope, My bike has had some work done to the motor.It kept popping the belts. No splatter, Have the O-ring chain which helps.
ORIGINAL: 128auto
Old 04-14-2007, 09:57 PM
balley's Avatar
balley
balley is offline
ORIGINAL: balley
Nope, My bike has had some work done to the motor.It kept popping the belts. I also went with a 150 tire (After deciding on chain) with stock fender. No splatter, Have the O-ring chain which helps.
ORIGINAL: 128auto
Old 04-14-2007, 11:10 PM
nessus's Avatar
nessus
nessus is offline
chain drives are stronger for the big inch builds plus they are narrow allowing for fatter tires
Old 04-14-2007, 11:17 PM
Stelis's Avatar
Stelis
Stelis is offline
Chain offers more efficient power transfer over belt.
Old 04-15-2007, 09:45 AM
whaap's Avatar
whaap
whaap is offline
Chain drives are more popular with racers because they're lighter than shaft drive. Shaft drive is the most maintenance free drive system there is. Belt drive is better for the average cruiser than chain is because it requires alot less attention (maintenance).
Quick Reply: Why chain drive ?
