Why chain drive ?
Old 04-15-2007, 08:11 PM
aceospades's Avatar
aceospades
aceospades is offline
Default RE: Why chain drive ?
ORIGINAL: balley
Nope, My bike has had some work done to the motor.It kept popping the belts. No splatter, Have the O-ring chain which helps.
ORIGINAL: 128auto
Very simple, an old school look. Right Balley?
I don't want to lube the chain weekly so I stick with drive belt, almost no maintenance.
how much does it cost to do this conversion?
Old 04-15-2007, 10:48 PM
nickdv9's Avatar
nickdv9
nickdv9 is offline
ORIGINAL: Stelis
Chain offers more efficient power transfer over belt.
I've heard read that the order of efficiency is chain/belt/shaft, but for maintenance its shaft/belt/chain.
Old 04-15-2007, 10:53 PM
balley's Avatar
balley
balley is offline
Done all the work myself. Rear Sprocket, Chain (Get a good one. i got the diamond O-Ring), Front sprocket, Front seal, may have to change spacer on front.
I think it cost me around $250.00.
ORIGINAL: aceospades
ORIGINAL: balley
ORIGINAL: 128auto
Old 04-15-2007, 11:38 PM
JBA111's Avatar
JBA111
JBA111 is offline
My first 1960Sportster had a little oil valve with a small 1.8" tube that bent over the chain. You adjusted it to drip a drop of oil on the chain every so many drops per mile. you just opened the valve if the chain started looking dry and closed the valve slightly if the chain looked too wet. The chain oil was the motor too!! Yea things got kinda messy!
And there is chain slap too that you don't get with the belt drive.
For top hot rod perfornmance get a good chain set up , otherwise give me the smooth belt.
VoiceofReason44
09-16-2017 12:16 PM
bass3167
06-15-2010 08:11 AM
jackinthebox
02-08-2010 08:19 PM
JohnK-NJ
08-23-2009 07:04 PM
abcd9906
04-01-2008 01:59 AM
Quick Reply: Why chain drive ?
