Coil issue
Coil issue
So been riding kind of hard and my rear plug wire will blow off the coil side. I relocated the coil back at the end of February. Used DK. Love it. Question being when this happens it blows off at the most inopportune times. Shocked myself pretty good riding in the rain and trying to get it back on.
Do I need new plug wires? I have switched the wires around and both are equally loose on the back coil connection. I'm guessing because both the wires work on the front and not on the back I may need a new coil? Can I wrap the post with tape to create a snug connection or is there a better way? Thank you in advance!
you may be able to pull the spark wire boot back on the coil end and spread the part of the connector that goes into the coil a little so that it fits tighter into the hole in the coil..also are you sure you are getting the spark wire into the coil all the way until it bottoms out in the hole, make sure you pull the boot back before you stick the wire into the coil and then push the boot back over the coil tower..also some dialectric grease may help you get the coil wire into the coil tower connector..
Received 4,216 Likes
I was doing some drag runs and the same thing happened to me...Wires had been on the bike for several years. I fixed it in 3 minutes...just squeezed the connector (on the end of the wire that goes into the coil) with some needle nose pliers and put it back in. Have not had a problem since.
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
run_ride_hide
12-22-2012 05:06 PM
