X14IED to PCV conversion. Quick question.
I am replacing the X14IEDs off my '07 1200C and putting on a Power Commander V. My question is, after I remove the X14IED, should I power cycle the bike on and off before I install the PCV? Should I start the bike without the X14IED? Ride the bike? Or can I just do the swap all at once?
Thanks!
Thanks!
Im going to do the same in a few days with a Fuelpak3. I was thinking of removing the Xied's and just disconnecting the battery for a bit. But if you think about it, at least with the Fuelpak3, it will take the current ECM map and store it, then flash a completely new map to the ECM.
So I wonder if you will be doing the same????
If I'm not mistaken, the Fuelpak3 changes the actual ECM maps.
I just wanted to be sure if I needed to clear anything out first.
Thanks
Our recommendation would be to just remove the X14IEDs and then follow the Instructions to install the Power Commander V. I would be careful riding the bike without anything tuning it.
__________________
www.DKCustom.com
662-252-8828 Voice
662-420-4891 Text & Voice
Support@DKCustomProducts.com
www.DKCustom.com
662-252-8828 Voice
I installed it. I ended up removing the X14IEDs and running the bike for 2 miles. Running through the gears and various throttle positions. Then I installed the PCV and ran the bike again. I won't know until a more thorough ride but I could feel the difference right away. Although the decel popping didn't disappear, it seems to be running stronger and has a nice throttle response.
I want to thank FuelMoto for the map they sent me based on the setup I gave them.
Thanks for everyone's help.
