Wobble, can't figure it out.
Ok guys the title kind of explains it all, I'm having a problem figuring out how to get rid of this damn wobble that I'm experiencing and I honestly don't know what to check to try and figure it out. We have some bad roads out where I live and I think a mean pothole that punched me in the spine may have knocked my wheel alignment slightly off?
1st and 2nd gear seem to be fine, however when I'm in 3rd right in the 2500-3200 range and I let got of the bars she starts shaking back and forth, which I find weird that 1st and 2nd dont really as opposed to just 3rd but I thought maybe 3rd just has more natural vibration than the other 2 and the bikes natural balance doesn't hold it together? mostly seems to be on deceleration also, but maybe a bit during acceleration but since I have a hand on the bar it doesnt seem to be too noticeable under acceleration.
I don't know its pissing me off and its my only transportation so I would have to make it a day of sitting at the dealership to see if they can figure it out. Ive heard that the rear suspension may sometimes be an issue that can affect this? The rims look perfectly fine, spokes good, front end doesn't visibly seem twisted or anything like that so I don't know. I think I'll have to bring it into the stealership.
2014 48.
2014 48.
Received 4,159 Likes
Yep, check the spokes should be done, front and rear wheels.
Also fall away...neck bearing. This is probably the most common cause of what you are describing.
Next would be the swing-arm...too much flex there can cause the front in to shake.
The shake may not be so much a gear issue or rpm issue as a speed issue.
With a manual, checking/adjusting the neck bearing is a fairly easy task...no need to have it tied up at the dealership.
2014 48.
2014 48.
Received 4,629 Likes
I doubt it's anything to do with the swingarm on a sporty, pretty solid with the spherical bearings. Don't know how many miles you have, but if the problem is recent, wouldn't think it was fall away; done right, that should be ok for a long time. A mean pothole could play havoc with spokes, even warp the rim. If you can lift the front wheel, spin it with something sitting next to the wheel, not quite touching the sidewall, so any wobble will be noticeable in the gap. If that tire moves more than an eighth of an inch from side to side, you might be feeling it on the road. Tap the spokes with a small screwdriver; any thumps instead of tings indicates a spoke that isn't torqued with the rest of them.
Most of the bikes I've ridden that had a handling problem were low on tire pressure, easy fix; but that usually isn't just a wobble, will get heavy and/or squirely feeling on corners, too. Let us know what you find, especially if it's something none of us mentioned. Good luck.
