07 883l wot start
07 883l wot start
my wifes 07 883l is not starting. turn key on, run switch, you hear the fuel pump kick on, hit the start button and it will fire up then die. it spit out the code for the crank sensor, $61 and it is still doing the same thing. the it spit out code for front injector open/low. anyone ever have this problem or any advice.
Sounds like the fuel pump to me.
If it was electrical it would run the same amount of time regardless of how much fuel it's using.
Sounds like the pre/prime builds enough pressure to start it but won't keep up once the injectors are firing.
I'm not near my service manual right now but there should be a procedure for checking flow volume, normally you would disconnect the line and run the pump for a given amount of time and measure how much fuel flowed into a container.
AMB2710
10-11-2021 10:45 AM
