Problem Rear Master Cylinder 48
I need some help.
The rear Master Cylinder on my 2012 Model X1200X seems to be leaking down the side of the cylinder at the cover. I first just wiped it off. I then noticed it continued, wiped it and removed the cover. The fluid seemed to be down about a small amount about an inch. I refilled and I am waiting to see if it continues. The brake is fine, the hole at the bottom was not exposed so I don't believe air ever entered the line. The MC has about 2K miles.
I inspected the cover and the plastic strainer both are OK. The reservoir has no cracks.
Does pressure ever build up to cause this? Has anyone experience this?
thanks,
Barrier
thanks,
Barrier
Re-build kit for the rear master cylinder. Part #42810-04B. As far as I know, that kit applies to a 2012, too, but verify.
Usually, the rear master cylinder takes a dump after changing rear brake pads or after simply removing/replacing the rear wheel. The instructions with the kit are pretty good. It's helpful to have a bench vise to perform the procedure.
My OL's '04 did it with 35,000 miles. When I swapped the pads on my '05, at about 20,000 miles, I cleaned the piston well, using a shoe string and brake clean, before pushing the piston back into the caliper's bore for the new pads' clearance. I didn't get the master cylinder failure on my '05 after replacing the brake pads. Maybe, I was lucky, and my cleaning procedure had nothing to do with it. Still, it's a good idea to clean the caliper/piston.
This is a common issue with HD master cylinders..people think a little tight is good so more is better....just tighten the screws enough to keep the cover on but not so much as to squeeze the gasket out...
