figure machine a/c
Just curious if anyone runs this on their iron 883. The price is $229. So a lot cheaper than the se heavy breather and on setup. Wanting to change out my ac and I like this look but want to make sure I'm not getting junk. Any feedback would be appreciated!
http://www.figuremachine.com/products/flow/xlflow-c/xlflowc.php?gclid=CjwKEAjwkrmhBRD49Mbm_MvruWsSJAAE Dt13Xinr3a_n1S0acWGiTABd5yvpYVpeWYJRsr3pqXZychoCGF 3w_wcB
My wife has this A/C on her 1200C. If you use the stock cover, I strongly recommend that you use the insulator that comes with the Screamin' Eagle kit. The insulator is sandwiched between the cover and filter. Without it, the mounting bosses on the filter will break off after some spirited riding due to the cover moving too much. The Mrs was not happy to be without her mule for a couple of days.
Received 4,166 Likes
Figure Machine makes some nice looking product. This is the first I've heard of any of their product breaking.
However, all their air cleaners are EPA compliant, putting the hot, oily, oxygen depleted, air from the breathers into the combustion chamber.
You may like the 636v just as well, and your bike will like it better!
With the patent pending 636v, your engine will run stronger, and last longer.
Check them out HERE
Check them out HERE
