Wheel Bearing Puller / Tool
I've been wondering about that. I keep hearing it has to be done with a puller but couldn't work out why you couldn't knock them out with a drift? I've got front and rear to do so hope that is the case?
I tried the cheap Harbor Freight puller and broke two of them before coming up with the solution.
I took a cheap pair of large pliers from HF and redneck machined a reverse hook on the back side of the plier jaws. Then I placed the pliers up in the wheel hub, hooked the jaws over the back side of the bearing race and using a long hardwood "punch" from the other side, drove the punch into the center of the pliers and drove the bearing race out.
The only thing you need to insure is that the notches you make in the back of the plier jaws are large enough to grab the bearing race, but not deep enough that the plier jaws score the inner face of the hub.
Worked like a charm and cost about $4.99 at HF for the pliers. Pluse I can still use them as normal pliers.
![Icon Mrgreen](https://www.hdforums.com/forum/images/smilies/icon_mrgreen.gif)
![](https://cimg3.ibsrv.net/gimg/www.hdforums.com-vbulletin/750x1000/img_20160312_181121156_f45f77ea6a6c0159e10ca361c4d67a930f6e2776.jpg)
The following 3 users liked this post by TStephen:
That's superb! ![Icon Clapclap](https://www.hdforums.com/forum/images/smilies/icon_clapclap.gif)
I was thinking you must be able to get a collet/mandrel in there and was looking at something like an expanding anchor bolt. Then I thought I might go all upmarket with a kit like the one below if it fits? Or, {{{shudder}}} pay my local indy to swap them out!![Icon Redface](https://www.hdforums.com/forum/images/smilies/icon_redface.gif)
http://www.ebay.co.uk/itm/5pc-Blind-...8AAOSw5VFWGhPW
Thx man! It's been said that necessity is the mother of invention, but I believe desperation is the real mother of invention. After breaking two bearing pullers and as it was getting late on a Saturday, desperation provoked some inspiration and, BAM!
I don't mind giving my local indy $ (better them than the stealership) for things I can't do, but paying for something you can do yourself is like giving money away.
Mr_Taipan (05-04-2016)
Received 4,626 Likes
I use a Pit Posse, a style of puller made by several different companies, from around $80 to a couple hundred, and has the parts to fit all Harley axle sizes. Harley bearings are usually real tight, tighter than a cheap slam hammer puller can handle. Any method that doesn't produce a straight pull will gall the sides of the wheel bore at least slightly, and enough repeats of this and you'll get a loose fitting bearing - that's the end of the wheel. I realize most folks won't change bearings enough to reach that point, and I probably won't either; still something I'm willing to spend a little on, though.
I also put the bearing in the freezer before installing and coat the outer race and wheel bore with a film of anti seize, just makes it a bit easier.
With the right puller/installer you can relax and let your grandkid do it, too, after he's put a new tire on.![Big Grin](https://www.hdforums.com/forum/images/smilies/biggrin.gif)
![](http://i1158.photobucket.com/albums/p601/imold/1%20-%20small%20mechanic/newwheelbearings.jpg)
