Wheel Bearing Puller / Tool
Just because a bearing uses a non-metal cage is no indication as to how good it is. I can give you a dozen stamped cage ball bearings that I wouldn't trust to run a pencil sharpener.
Received 4,627 Likes
There are probably a dozen bearings in your motor that use synthetic cages. Almost every bearing in your transmission uses PA66 cages. There is nothing wrong with it, and in fact it can be preferred for certain situations. There are a lot of benefits with synthetic cages.
Mr_Taipan (05-07-2016)
