what is normal for a jiffy stand
I have a 00 883 hugger that I have put taller rear shocks and taller tires on
now the bike leans way over when on the side stand...how do I figure out what size longer jiffy stand to put on it???..I figure an inch or 2 longer wound be good, but don't know what normal is, as the bikes stand is now the shorter one that was used on the huggers.. do I just measure it add 2 inches and buy one by length..it seems to me that they advertise jiffy stands as 1 inch or 2 inch longer than stock and I am not sure of what stock is...
Just get a non Hugger Sportster jiffy from the same year. I had a simular problem as you. Guy I bought mine from lowered the crap out of it and put a Hugger jiffy on it. When I put 12.5" shocks back on it and raised the front I had to replace the jiffy stand. The original stand worked great. I found mine on ebay. http://www.ebay.com/sch/i.html?_saca...&_sop=7&_frs=1
Good luck.
Good luck.
it is taller in the rear when it on the side stand, but when I sit on the seat it levels the bike out to about where it was stock, except the whole bike is a little higher because of the taller tires..And something I did not mention because it was not revelent to the matter at hand is the bike is even taller now because I installed a coil spring seat, but I am tall so reaching the ground is not an issue for me...
stand length
When I added length to my XL Custom shocks, it leaned over too far as you described. What I did, was cut out a piece of wood, and attach it to the bottom of the existing stand. I drilled two holes in it for mounting purposes. Plus, it is slightly larger than stock, so it is less likely to sink-in to softer ground.
