FS: Wild1 16" Chubby Springer Apes And Cables
Hey Gang,
I've got a set of Wild 1 16" Chubby Ape Hangers for Softal Springers (WO569). They are 1.25" in diameter and are satin black in color. They are in very good condition with very minor normal signs of wear.
I also have a set of silver braided (diamond back) lines for the bars. This includes throttle/idle cables, clutch cable and break line. These are also in great condition. I am not sure if these are Burly brand, H-D brand or some other make. I got them pre-owned with the bars. They seem like really good quality in both make and finish.
I got this setup pre-owned for my Crossbones but never installed them and don't think I will ever run them.
The bars alone retail for well over $200. I'd like to get $200+shipping for the set-up.
Would also consider doing a trade for another style of Springer apes such as Wild One Outlawz in 14 or 16 inch with black cables.
Skeez
Skeez
Skeez, send me pics: deepsleepcoffee@gmail.com
Im interested...
Im interested...
Hey Gang,
I'll post photos of everything as soon as possible.
Skeez
Skeez
Unfortunately I am pretty certain these will not fit a non-Springer model. The reason being that the spacing between the risers on a Springer is much wider than those of a non-Springer. As such, the points where the bars reduce to 1" in the center in order to fit stock risers will not line up with your risers.
I know that on Springer models, you can swap out your top tree with one that relocates the riser position in order to run non-Springer bars. However, I have never heard of something similar that you would use run Springer bars on a non-Springer.
Okay, Blast. I will get photos tonight. I will post them here as well as send them to you.
Ok thanks!
Unfortunately I am pretty certain these will not fit a non-Springer moderl. The reason being that the spacing between the risers on a Springer is much wider than those of a non-Springer. As such, the points where the bars reduce to 1" in the center in order to fit stock risers will not line up with your risers.
Skeez, pics pls. deepsleepcoffee@gmail.com
Thanks!
Thanks!
Hey Gang,
Skeez
Skeez
Here are some photos. Sorry for the delay.
Bars...
Cables...
Detail of cables and clutch cable adjuster...
One end of the cables...
The other end...
As I said before, I can not be certain what brand cables these are. The bars are in fact Wild Ones and have the name and part number stamped on the end of one of the bars. The cables came in a plastic bag with a Harley Davidson label on it but a good part of the label is missing so I can't even verify if the cables came from this bag originally. That said, they are really nice cables and the only reason I don't plan to use them is because I am not too much into the chrome look. I like the bars but decided that I might want to go with 14" Wild One Outlawz.
If I don't sell these I may try out the bars and see if my brother is interested in the cables for his Rocker C.
Thanks
Bars...
Cables...
The other end...
Thanks
Skeez, are they black or chrome bars???
Bars...
Cables...
The other end...
As I said before, I can not be certain what brand cables these are. The bare are in fact Wild Ones and have the name and part number stamped on the end of one of the bars. The cables came in a plastic bag with a Harley Davidson label on it but a good part of the label is missing so I can't even verify if the cables came from this bag originally. That said, they are really nice cables and the only reason I don't plan to use them is because I am not too much into the chrome look. I like the bars but decided that I might want to go with 14" Wild One Outlawz.
Thanks
Bars...
Cables...
The other end...
Thanks
They are satin black.
