The cv137 works with detachable hardware, the studs are longer for it. The cv136 are too short to go through the docking hardware and into the fender rails. They use the same description for both on their site, but make the distinction in the list of parts they sell.
Not if the sissy bar is detachable. The cv136 studs are about the same length as the stock fender rail bolts. They aren't long enough to go through docking points that are used with quick detach accessories.
I'm guessing that if I have the Lo.get bolts to go thru the rockin.g hardware that these will work? Any ideas? I have not seen these before but like the idea of them.
[QUOTE=beasleyiv;10763745]Not if the sissy bar is detachable. The cv136 studs are about the same length as the stock fender rail bolts. I'm lookin at the CV137s too. I finally broke down and got bags. Have you ever heard of the longer bolts breaking? BTW I used to drive for RAM trucking up there. I used to pick up laminated beams at Weyerhaueser at exit 234. I miss it up there. Cool folks. Thanks for any info. L8r.
