Harley Deuce Wide Tire Rear spacer kit
Old 05-16-2010, 08:29 AM
baccalasports's Avatar
baccalasports
baccalasports is offline
Default Harley Deuce Wide Tire Rear spacer kit
Harley Deuce Wide Tire spacer kit will allow 180 tire on deuce rear wheel
The following items are included with this kit:
-1/8" thick pulley spacer that has the correct outside diameter that covers the hub casting holes, and works with the O.E.M. rubber gasket.
-Alignment spindle that once bolted in place aligns the pulley to the I.D. of the hub.
-This is needed because once you space the pulley out 1/8, you loose the use of the hub locating diameter.
-1/8" thick axle spacer
BOUGHT FOR 45.00 NEWER USED
WILL SELL 35.00 SHIPPED
PM ME IF INTERESTED....
Attached Thumbnails Harley Deuce Wide Tire Rear spacer kit-2749ch1_20-1-.jpg
Old 05-25-2010, 01:24 PM
baccalasports
Sold !!!!!!!!!!!!!!
BlockHead96
04-16-2021 05:32 PM
trkyhtr113
03-09-2019 08:41 PM
bensonjv
12-17-2011 03:03 AM
streeteagle
05-22-2010 04:51 AM
rrcrum
06-07-2009 07:53 AM
Quick Reply: Harley Deuce Wide Tire Rear spacer kit
