VANCE & HINES SIDE SHOTS (No O2 fittings) Twin Cam 88 motor $200
VANCE & HINES SIDE SHOTS for Harley Davidson, off a 2005 Softail (will fit Dyna and other Twin Cam 88 engines) with only 5,000 miles on it (lightly used condition.) These are performance headers!
Comes complete with brackets (50.00 option when new) shields, rings etc... NOTE: this model does not have O2 sensor fittings on the pipes. For an 88 Twin Cam carb model, no fuel inj.
Had to replace them because in my subdivision it was way too loud. Put stock ones on but sure do miss the distinctive V&H rumble these Side Shots cause!
FROM VANCE & HINES: SIDE SHOTS- Style and performance all-in-one, your 2-into-2 pipes with a twist of style and power; Sideshots deliver increased horsepower and torque served up by revolutionary Vance & Hines Power Chamber technology. Hidden under the heat shields, the Power Chamber uses the volume of both mufflers to improve scavenging of each cylinder for more efficient combustion. With massive full-length 2 1/2” header and muffler heat shields, this system is blue proof for long lasting style. Twin slash-cut ends are added to finish off the look and leave you with the ultimate in style, power and sound.
http://www.vanceandhines.com/product...sideshots.html <- For Dyna
http://www.vanceandhines.com/product...sideshots.html <- for Softail
you got it bro!
Yep that's right!
But I wanted to make absolutely sure guys know that it does not not have the 02 sensor fitting.......
Would hate for a bro to buy these and when it gets to their house it won't work on account of the fittings not being there. I had to special order these pipes when new "without" the fittings, ya I know like the dealer said why not just put a plug in the pipes but for me it's not the same!
You get what the part calls for and no make shift "rigging" and for me putting a pug in the pipe is make sift *&(^%(&* rigging.
Dutch..... OUT
Dutch..... OUT
Dan103
Touring Parts
11
07-13-2016 05:51 PM
88, 88 twin cam, cam, carbureted, dyna, headers, horsepower, o2, pipes, put, sensors, softaill, sportster, twin, vance and hines exhaust
