are cams worth it?
Yes they are very worth it!!!!
Kind of expensive..... Several hours labor (maybe 8) or you can buy adjustable pushrods and save 3 hrs labor.....
Parts and labor $1000-$1500 rough guess, + tuner
But I would not mess with SE cams... I did, and then went with a Wood's cam - much much stronger in every RPM
I did Andrew 48s on my 09 fatty , Best investment so far. Runs like a Different motor. Cant wait to do my 13. So answer your question Yes , Cams are worth it ,you should get it dynoed and tuned by a professional .That is very important.Cost depends If you have dealer do it all probably 2500 plus dollars with everything .( exhaust ,cams ,tuner ,dyno, air intake,your service and labor.
