popping on deceleration
I installed Vance & Hines big shots long on my 2013 Heritage. I put in the quiet baffles to reduce the noise and installed a V&H Fuel Pak to calibrate the exhaust and to remove the popping and backfiring. I am still getting a bit of popping on deceleration. Now I'm wondering if upgrading the air intake will eliminate the popping completely or if what I have now is the best it can get with after market exhausts? I am not interested in more power so should I save my money or upgrade my intake? (probably V&H VO2 intake kit)
Yea, changin the air cleaner will NOT help at all, maybe make it worse. You have a lean condition. I've used FuelPaks and frankly never kept one on long, just not much more than a stop gap fix. What you need to do is put on that aircleaner and get a better fuel device and have it dyno tuned by a competent tuner.
I found that by double wrapping the quiet baffle with fiberglass packing eliminated decel popping. Just be sure to use thin wire (tightly wrapped) to hold the packing in place. The tape that V&H supplies is a joke. If you don't wrap it tight, the packing will eventually bunch up in the front of the baffle and allow less back pressure. Also sounds pretty good.....with long shots anyways.
I have V&H staggards, SE AC and a fuel pack and I get some decel pop from time to time but nothing like I got before I added the fuel pak.
I guess I'd have to know what you mean by "I am still getting a bit of popping on deceleration".
Is that all the time or just some of the time?
Before I added the fuel pak I got it all the time now I only get it just some of the time.
Also many people slam the Fuel pak but for the money I think if you are only going to stage 1 spending anything more is a waste because an advanced tuner can only do so much with stage 1 setup.
