Heat Shield Rattle
Look real hard for the hose clamps. They are put in places so you can't see them while viewing the bike. I'd recommend checking the torque on the flanges and snugging down the heat shields. If the clamps broke that's an easy swap but if the clamp mount is broke then your SOL. If all else fails might try wadding up foil, etc.
Thanks CajunIron -- found the clamps - - one was a bit loose. Also found that the heat shield was touching the muffler -- bent it out a bit.
Cheers,
Balloo
I had a Sportster a few years ago and had the HD service dept install some V&H big radius. Two years later all except one of the mounts on the inside of the heat shield had snapped off. Not the clamps...the mounts. Called V&H and they said they would send me a new heat shield once they produced some more. I traded that bike in before that ever happened.
rhino49er
07-26-2007 08:30 PM
