Question about the CVO Breakout foot controls
Great! Let me know how much you'll enjoy this mod! I did enjoy it!
Not sure if you have already figured things out but I ordered the HD Extended Reach Forward Control Kit P/N 49171-08 and the HD Extended Reach Forward Control Rear Brake Line P/N 44972-08 for my 2014 CVO Breakout and installed them both. As everyone noted, the left side bracket and controls were easy to install but the right side took a lot more time due to difficulty accessing the Rear Brake ABS pump. In order to remove the OEM brake line and install the extended reach brake line I had to remove the heat shield from my lower V&H Big Radius 2 pipe in order to gain access to the clam shell housing unit. As stated in earlier posts, if you slide the plastic fender guard out of the way, you gain some extra room to undue the allen key bolt holding the housing together. Once that's done, you can slide the solenoid out of the housing and you can have the access and room to remove the old break line and install the new one. The HD service manuals and parts manuals say that these parts won't fit Breakouts but they do. Let me know if you have any questions.
